Hi guys im am new to Dynamo and am in need to some help with adding a Mark to a dynamo script. Basically I have a roof with 250 unique sized curved sheets and I need to add a mark to each one so that I can identify them on site. Please find the script attached which allows the curved length to be reported. Any ideas how to amend thescript to allow it to report a mark on each sheet which would then allow it to be exported to excel?
If you want to keep the length information in the element, you must create a shared or project parameter of type length.
You will then use the Element.SetParameterByName node to populate the value in the elements like this :
Hi Alban, I have created this script but it says: Warning: Element.SetParameterByName operation failed.
No parameter found by that name. You have called thre parameter Type Length but the script refers to Sheet Length is this correct, should these be the same?
I have added ther parameter to the family then lnked it to the project using gloabal Paramters is this correct?
Also what type of paramter must the Length Type be Text or Length?
Can you show a screenshot of the properties of your family in the project ?
Do you see the Sheet lenght parameter in the family properties in the project ?
HI Alban, I finally go the script to work but nothing is populating on the custom SHeet Length Parameter inside of the family. What do I need to do for this to happen?
It also is not outputting anything as it fails saying : Warning: One or more of the input types are not matching. Couldn’t find a version of Excel.WriteToFile that takes arguments of type Function??
I thought that this script took the individual lengths inside the project environment then populated them within each family so that they could then me scheduled normally (as being curved adaptive families they do not so this normally). Not to worry.
Back to my original question how do i now add a Mark to each sheet?
