I am trying to place an adaptive component (a rectangle that will be used for a sweep) at each point perpendicular to the curve. When I try this, all the profiles are parallel to the ground. Can some one help explain why this is happening? thanks in advance!
geometry test.dyn (56.5 KB)
Dan_Lamm
1
Likely need the rvt as well. ![]()
Related topics
| Adaptive Component by three points | 0 | 587 | April 20, 2017 | |
| Place families perpendicular to a curve | 6 | 305 | June 23, 2025 | |
| Adaptive component along two divided curves | 14 | 1243 | October 22, 2018 | |
| The orientation of the Adaptive | 7 | 1814 | January 18, 2018 | |
| Adaptive Component By Points | 14 | 280 | January 24, 2024 |
