Hi guys!
How can I access wall/floor function in Revit in dynamo? The picture is attached. By default, I have not found any node, which can help me access this. I want to use an if statement, which will tell me whether the material is finish or structural and calculate its area or volume accordingly.
You can use the Get CompoundStructureLayers node or depending on your Revit version the FamilyType.CompoundStructureLayers node.
Another question
If I want to access the function in Python script, how to do it. Basically I want to calculate area for Finish and Substrate layers and volume for the rest.
