Accessing Visibility Control of Coordination Models in Revit 2022 with Dynamo
Hi All,
Is it possible to control visibility of Coordination Models in Revit with Dynamo? I have tried the below with no success.
I’ve even tried applying these settings to a view template and then applying view template properties to a view, this doesn’t even control this setting
The reason behind this struggle is that when a Coordination Model is linked into Revit this triggers Raster Processing when exporting views/sheets to PDF even when the Coordination Models are no longer loaded.
Which means the 400+ drawings that do not need to see the Coordination Model still print in Raster.
Many thanks if anyone can assist!
@JBH late reply, but worth posting:
clr.AddReference('RevitAPI')
views = UnwrapElement(IN[0])
bool = IN[1]
for view in views:
	if bool == True:
		view.AreCoordinationModelHandlesHidden = True
		result = "Coordination models are hidden"
		view.AreCoordinationModelHandlesHidden = False
		result = "Coordination models are visible"
OUT = result
@Elie.Trad Thanks so much!
I found another very clunky work around using view templates. The python solution works much better!
Hi, it is posible to apply only to a current view, im trying but it doesn work.
Im leanring so, im not an expert coding, ill apreciate your help. Thanks
Captura de pantalla 2024-07-15 152043
@asoriaq include the view in a list is the easiest way:
Thanks for answer, works perfectly
Hi, I’m currently new in python scripting and dynamo, and I tried doing this and I’m having still issue on the line 15. Let me know what I did wrong and I’m glad to learn from you
Convert views to a list. You are feeding it as a non-list. Use this line for views: views = UnwrapElement(IN[0]) if isinstance(IN[0], list) else [UnwrapElement(IN[0])]
Thanks, I did plug it in on the line and it works.
