Is it possible to sccess the „Name“ value given to different Objects in a SAT file ?
Goal: import SAT into dynamo, sort objects by these Names (dictionary) to retrieve them.
(The Names show when opening the SAT as text, but geometry import only shows type: solid, surface etc.)
I am not aware of any AEC tools which do this, in Dynamo or otherwise. Perhaps there is a manufacturing toolset which does this? You could write your own importer, as the spec for SAT is somewhat available for review.
http://paulbourke.net/dataformats/sat/
Thanks Jacob, I had read this and was surprised that „name“ actually exists in sat…
So from dynamo geometry export out to sat , is there a recommended way to attach a string to a piece of dynamo geometry ?
Nope. You’d have to build a custom exporter as well.
