Hello, I want to load the rfa file from the rvt file in revit and do a repeat of exporting ifc or symbols, is there a package or script I can do with dynamo?
Hi Park, welcome ![]()
I sure there are possible solutions - your request is fairly broad, are you able to show what you have tried or are trying to do with examples
Please take the time to review this post How to get help on the Dynamo forums, if you haven’t done so
I want to import the Rfa file one by one to Rvt (project file), export it to ifc, delete it, and then import and export the rfa file in the file path again. The problem is that if I set the ifc extraction setting I want, I only import the rfa file from the rvt file, but ifc cannot be extracted I think there’s a problem with Python scripts
줴줴이야.dyn (20.3 KB)
what is the problem ? (share what you’ve done)
