i want to generate that inplace family automaticly… doesn’ t need to be an inplace family but i need the mass so could also be saved as a family
Is there a reason you need a mass?
I tend to use .stl for 3D printing?
Cheers,
Mark
sorry Mark, i ment it isn’t necesary for 3D printing. I just want the building volume… the 3D printing is a nice extra
@Arno_De_Lange Since you seem to have openings in place of windows, the easiest way might be to delete all doors and windows and run the script. You could always undo and restore the doors and windows.
volume2.dyn (48.5 KB)
Agreed…
Presumably windows are modeled with no extrusions so they were as simple as possible… But this means there is no geometry to extract, so the node throws an error…
Best not to include them in the graph. I also added in Rooms (the was an upper floor Room missing in the model)… Then it seems to run correctly?
Cheers,
Mark
3DPrint rooms.dyn (17.7 KB)
Hi and thanks for the previous posts - very helpful.
Today is my 1st day looking into 3d-printing from Revit/Dynamo,… I took the above graph and added a few nodes from the MeshToolKit package and exported an .stl. I used the Revit 2017 sample-file as geometry and tried to add a few more categories. Could only make the “Structural Foundations” (Slab in the parking lot) work. Stairs won’t work and Curtain Wall Mullions/Panels won’t work either. Would be nice if anyone knows how to deal with those items…
Checked the resulting .stl file in Rhino and got a valid mesh with no naked edges.
Hey,
If I could just point you to my post above…
The key thing for printing is to get something that prints.
Your 3D printing software likely doesn’t care about booleans, as long as they are Solids, it’s fine to print them, so don’t get too hung up on it.
Reviewing in Rhino is a good idea, but the real test is to put it into your 3D printing software and check it.
E.G. Rhino will tell you that the window glass is fine, but actually it is likely too thin to print.
E.G. Dynamo can’t boolean a floor and a wall, but actually the 3D printer is able to print those just fine
E.G. Meshmixer might highlight the underside of floors as not being able to print, but actually the 3D printer can print on empty air and cantilever the threads accross to the wall.
So in sumary, just extract the solids from the curtain walls, foundations and stairs and use them without booleans.
As a side note, you will likely need to amend handrails to be thick enough to print, (you need to think in terms of the physical process of printing more than the virtual world).
Hope that helps,
Mark
Sorry to dredge up a really old post but I’m trying to work out what the point of the code in the green box is:
As far as I can see it just takes a bounding box and subtracts the solids created by the walls, doors etc. So you’re left with a ‘mould’.
But then you take out the solids that are the same as the bit before the green box and join them back together?
Note that the solid with the largest volume is dropped. (The ‘mould’)
The rest now also has the room volumes which wasn’t available in the original selection of elements. This helps create a ‘solid’ mass.
Thanks for the reply. I’ve tried it with a couple of models but it doesn’t seem to make much difference for some reason.
The model should be water tight. This exercise only makes it solid. If the voids within leak to the outside, it joins the ‘mould’.
Please upload a model, if possible
So I’ve picked up the same challenge today of a ‘close to one-click solution’ to get a scaled revit model to an stl file that our design team can slice and 3d print. I believe I’ve run in to the same issue that @Alien ran into.
I understand the idea that the building element’s solid model is subtracted from the bounding box solid, creating a collection of solids that represent the void spaces. Then you remove the largest volume void space, as it should likely be on the exterior of your building model. What you’re left with are the building interior volume solids.
Finally ,you combine the building model solid with the building interior volume solids to create a model that is ‘solid’ on the inside (no interior walls, doors, ceilings, etc…). This makes a nice clean print.
What I’m running into though, is I’m not getting the building interior volume solids. I seem to be getting a duplicate of the building solid model. Any thoughts?
I figured out my issue. I’m working in Revit 2023 and Dynamo 2.16.1. it appears the Solid.Union node only combines two solids, while the Solid.ByUnion node will take a single level list of solids and combine them all in to one solid.
