I do not why but I got Revit 2020.2 with Dynamo 2.3.0 and I am missing 3D preview. I can see Grid so it is not graphic card issue.
Any help will be appreciated.
Is there any way to re-install dynamo for Revit 2020.2?
Not sure how to solve my problem? and why I can not see preview…
Hi @Michal_Dengusiak can you try installing https://www.microsoft.com/en-us/download/details.aspx?id=8109
Hi Michal_Dengusiak, Where did you find the option on this image:
I’m having the same issue I have Dynamo on Revit, I tried on the Nvidia control panel but did not fix the issue.
Where exactly you find that option “run with graphics (default)”?
I’m missing that option. I searched for some troubleshooting I found that option was removed according to a recent update.
And the Nvidia control Panel is not helping with all the Revit options I don’t know which one to pick.
They let me edit but it does not fix the issue.
It shows more than one option on the drop list, I only have Revit 2021 installed. Also when I want to add a program I get at least 5 Revit options and a Dynamo Player Icon is there as well.
list,
I also have the Autodesk Revit with the Grayed out options like the one you have, Sometimes is there, but then I remove it, and then I cannot add it again.
Another troubleshoot said that I need DirectX10, I tried installing it but the Windows site is down.
I’m not sure if I will be capable of fixing this issue. Is it ok if I try running dynamo on a blank Revit project?
How necessary is that 3d preview for Geometry?
Thanks for replying.
