I recently installed version 1.2.0.2560 Dynamo. I’m trying to create a dimension between the faces via a node Dimension.Byelements. Is it possible? Or this node creates a dimension just between the axes of the elements?
@Albert_Valiev Please create a separate forum topic/thread for your question. Also, please make sure to post any screen shots of your work or warnings. Thank you.
please next releases make more lightweight interface program…is so hard to work with complex geometry in Dynamo
@Zach_Kron Updated to Dynamo 1.2 not including the changes to list management in “List.GetItemAtIndex” as described above? on two different computer installs.
@Mike_Engel1 you mean you aren’t seeing the list@level behavior? Click on the > on the input ports.
Also check out this post:
http://dynamobim.org/introducing-listlevel-working-with-lists-made-easier/
This topic is no longer a banner. It will no longer appear at the top of every page.
Wow, I feel a little silly for even asking, thought I tried that, yesterday was just that kind of day.
And a great tutorial! well done.
