Hi, is it possible to make a script in dynamo that show and zoom on a element in Revit. For example, if I know the element’s Id and run the script, it shows me the element in Revit.
is it clear enough?
Thanks!
is it clear enough?
Thanks!
Something like -Selected Element- >> keyboard shortcut BX??
I think the easiest way is simply to click on the element Id. It will directly show you the element on Revit.
Yeah, that’s pretty much what I want. But, I’ll try to explain what I want exactly.
I create a script that ask the user to enter a certain string and choose a categorie. The script will use the string and the categorie to delete elements with a name close to what the user enter and ask if he is sure to delete this/these element(s). So I need a note that show which element the user is about to delete.
