I put everything in one class and it didn’t change the import of the whole system category.
I did manage to get the select method to stop showing up by marking it abstract.
Here’s a peak at my code, (Be gentle I am a noob at this for sure.
###My Selection Class
using Autodesk.DesignScript.Runtime;
using Dynamo.Graph.Nodes;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
namespace Beaker
public abstract class Selection
/// <summary>
/// This node will take an input list and allow you to choose items in it.
/// Compatible with Dynamo Player.
/// </summary>
/// <param name="list">Input list</param>
/// <returns name="selectedItems">The user selected items.</returns>
/// <search>
/// Pick, UI, Filter
/// </search>
public static List<Object> PickItemsFromList (List<Object> list)
List<Object> listReturn = new List<object>();
PickFromList window = new PickFromList();
//selectList
window.listBox.ItemsSource = list;
var res = window.ShowDialog();
if (!res.HasValue && res.Value)
window.Close();
var data = window.listBox.SelectedItems;
foreach (object element in data)
listReturn.Add(element);
return listReturn;
###And the class for my XAML
namespace Beaker
[IsVisibleInDynamoLibrary(false)]
/// <summary>
/// Interaction logic for PickFromList.xaml
/// </summary>
public partial class PickFromList
internal PickFromList()
InitializeComponent();
private void accept_button_Click(object sender, RoutedEventArgs e)
DialogResult = true;
private void listBox_SelectionChanged(object sender, SelectionChangedEventArgs e)
