I am not sure why I see this error:
It’s about this line here:
Hi @danail.momchilov with this issue, we have so many reason to explain why, can I know more detail about version of dynamo also what platform software you are working on ?
I see, in this particular case it’s Revit 2021 with Dynamo 2.6
I am creating some nodes as Visual Studio Project as Zero Touch nodes. For some reason. System.Math fails to load in Dynamo
You can try to create a project extension and use resolve assembly to try load again :
This is example you can reference.
thx I will give it a try. I also had another idea, could it be due to the project and Dynamo using a different .net version? I have set the one in the project to .net 6?
Yes. That would be problematic.
You want to utilize .NET 4 for everything except a Dynamo 3.0 tool, and since Revit utilizes 2.6 to 2.18, you’re in .NET 4 land. ![]()
.NET 6 won’t work with Revit 2021 anymore, you net set with .net framework 4.8
yeah that fixed it, thank you all! downgrading the .net version caused a chain reaction of other issues but I made it through
will be a good lesson for next time
