Z topography intersection polysurface
Hi
I’m trying to get the z coodronate of my topography using either :
  • the node topography.surface
  • the corresponding script
  • or the method using the geometry intersection
but the only result that I get is the same unique point…
If someone can help…:sweat:
Capture01
The issue is hard to see on this screenshot. You could try to flatten your list of point before Point.Project instead of using the lacing, or in general terms, play with the structure of your lists so that they fit together. Please try to send a screenshot that isolates the potential issues so that we can quickly see what it is about.
kind of flatten problem + the dynamo interval number range I think
tkx anynway
