Hi to all. I exported XYZ coordinates of structural foundations from Revit using the Get Family Instance Location component the coordinates values are only in Project Base Point. Can I get those values in both type of coordinates Survey point and Project Base Point. Thanks for the help.
I am fairly sure their was a similar post about this on the forums but i cannot find it at the moment.
You need to transform the locations points you get into the real world coordinates, this is usually done by transforming the coordinates, which their is a node within the archilabs package(total transform).
Sorry it doesn’t fully help but hope it directs you in the right direction
