I am using these nodes to export the date in a specific format. However, in the excel cell the date is reversed.
Why is the date reversed?
Hello @JC.Moreno …think the dateformat is controlled by windows
Thank you @sovitek. I solved the problem.
Great how ?
I used a python script node to reverse the date. It is not a greate but it works for the moment
import datetime
# get the current date
current_date = datetime.datetime.now().date()
# convert the date to a string in yyyy-MM-dd format
formatted_date = current_date.strftime('%Y-%m-%d')
# output the formatted date
OUT = formatted_date
As @sovitek mentioned you could also check the settings in windows by going to:
Yes I have this in my case:
j = jour = day
M = mois = month
a = année = year
Have you confirmed that the particular cell you’re looking at in Excel is formatted the same? This seems more like an Excel issue, especially since Excel will auto-format anything that looks like a date.
I have this format in excel
It’s probably an issue with Excel auto-formatting then. Since the value you’re sending to Excel is just a string (not a formatted date) Excel is probably assuming a format of MM-dd-yy and converting that to dd-MM-yy. I think your current workaround of changing the initial format is your best bet. You essentially need to make sure that the format you’re providing Excel has no way of being misinterpreted (if you’re going to use Excel formatting) or that you force the Excel document to use no formatting at all (string and/or number only).
