I’m in the process of setting up Dynamo so it can read in data from excel and upload it into various pieces of equipment in Revit. I’ve found another problem with my current setup.
Here’s what I have at the moment:
I’ve assigned a parameter “Mark” in Revit, and then I name the AHU’s in this parameter, corresponding to those from the schedule
This is all working fine, however it’s not very robust. For example, I have AHU-10-01 up to AHU-10-08 in the schedule. If I want to delete AHU-10-03 in Revit, but leave the column in the schedule in case I want it in the future, it will incorrectly assign the data, as it will just do the first 7 columns, rather than skipping the third column, and continuing on.
Another problem is it also assigns only in alphabetical order. The schedules should almost always be in alphabetical order, however if someone was to add another column to the end, and it wasn’t the last piece of equipment in an alphabetical sense, it would again mess up the order.
What I need is some sort of “check” happening. I have the names of the equipment from excel (seen in the List.Deconstruct (first) box). But I need to go through the equipment in Revit, see if the “mark” value matches a certain column, and then upload the data, but I’m not sure how to do this.
