That worked!
Thank you
That worked!
Thank you
@Bobby_Harris1 No problem! Did you have success importing the data from Excel back to Revit as well? Please mark the solution (post #18) if your query has been solved
Nope⦠just the read was successful.
Warning: Element.SetParameterByName operation failed.
The call is ambiguous between the following methods or properties: āRevit.Elements.InternalUtilities.ElementUtils.SetParameterValue(Autodesk.Revit.DB.Parameter, Revit.Elements.Element)ā and āRevit.Elements.InternalUtilities.ElementUtils.SetParameterValue(Autodesk.Revit.DB.Parameter, string)ā
Wall Read to Revit.dyn (9.7 KB)
Oh wait⦠@awilliams Success!
Not sure what happened but it did work!
You must have missed the note I put above the Element.SetParameterByName node ![]()
Glad youāve gotten it working!
I did see that note⦠the changes didnāt take effect till I closed dynamo.
Regardless I am grateful for your time and help.
