Does anyone know the best way to check if worksharing in the current document is enabled. I know a lot of ways to check like checking an element if Workset
and Edited By
parameters exist but there should be an API for that. I looked around the Revit API documentation but haven’t found a nice way.
Thank you in advance.
-Biboy
Just query one model element for the workset
That will conclude if it is
Hi @Marcel_Rijsmus,
Thank you for your sugestion but thats one of the ways I proposed aboved. I was hoping for an API like doc.IsWorkSetEnabled
or doc.IsCentralModel
or doc.IsLocalCopy
or doc.IsCollaboration
etc.
@blsalvio Try this
OUT = doc.IsWorkshared
@AmolShah
thank you very much, I was searching in the application class, I should have been searching in the document class.
