Is there a way to get the active workset in a document using Dynamo? I have a script that I want to run only on the elements in the active workset, so I’d like to be able to pull the workset ID and filter elements based on that. I haven’t come across any nodes that do this.
Hi @brunelli.b,
Put this in a python node, and see if it does what you need:
#Import the Revit API
clr.AddReference('RevitAPI')
#Import DocumentManager and TransactionManager
#Reference the active Document and application
#Start scripting here:
wt = doc.GetWorksetTable()
wId = wt.GetActiveWorksetId()
OUT = wId
Thanks a lot. That works perfectly.
