I have the following graph that seems to work; however, when I run it, the Worksets are not inputted in the order in which they are written in Excel. Any ideas?!
Hi @fwilsonKDDWT ,
This isn’t a dynamo thing.
Try to create workset (100_XX, 200_XX…) in Revit and it will be the same.
Try also to sort your list in excel to see what’s going on.
It’s the machine alphabetical order.
You were waiting for Natural Sort Order.
Thanks, @Alban_de_Chasteigner!
You are correct, it was a simple Excel sorting/format issue.
Still very new to Dynamo, so I always assume I am messing up in there.
Thanks again!
You’re welcome.
Can you mark the post as solved please.
