Hello all!
I am working with the data-shapes node and am trying to work with list data.
Here is my script. I am trying to display all the elements (second input) based off the selection of the category (first input)
When I select, structural framing, I would like to see all the family types in structural framing.
I would like the UI to update the second list automatically based on the first list.
Let me know if you have any questions.
Data-Shapes (Dynamo) doesn’t update this way. A node only executes once per run. You need to break this into two separate windows (nodes). One to select the category and one to present the elements of that category.
- Data-Shapes window prompts for selection. Select category.
- Use output from selection to get all elements of the selected category.
- Feed those elements into new Data-Shapes node for element selection.
Makes sense. Thanks for the quick response! Have a great weekend!
Hi, Which version of Data Shapes is that? Im intrigued by the check boxes opposed to the drop down list which i get from version 2022.2.105
Thanks in advance
The list of check box options is from the Listview Data node.
Hey @Jason_Lindner. Were you able to figure everything out? Looks like @Nick_Boyts gave you a good answer! Let me know if you have any more questions.
