Storm
October 20, 2022, 9:11am
1
Hello every1)
I have a script that uses selected elements in the work (a little more convenient than the standard Select Model Elements, No need to press “Select” and then choose)
In 2022 Revit works great, but in 2019 it gave the error “Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.”
I thought that the syntax had changed and decided to try with a standard node, but it also gave me “Null”. How to work with text (TextNode) in 2019 Revit? More precisely, how to select it?) The rest of the script should work if I can get the text as an element
clr.AddReference('RevitAPI')
from Autodesk.Revit.ApplicationServices import Application
reset = IN[0]
ids = uidoc.Selection.GetElementIds()
idd = [str(i) for i in ids]
if isinstance(idd, list) == True:
elems = [doc.GetElement(ElementId(int(i))) for i in idd]
elems = doc.GetElement(ElementId(int(idd)))
OUT = elems
@Storm ,
i can`t test it … but look on your syntex and libraries
import sys
clr.AddReference('System')
reset = IN[0]
OUT = elems
Storm
October 21, 2022, 8:05am
3
Hello @Draxl_Andreas ,
Unfortunately i get same error
Just Ctrl+C Ctrl+V your code
Your selection code seems a little more complicated than necessary. Here are the two lines of code I use to acquire the current Revit selection.
sel = uidoc.Selection.GetElementIds()
sel = [doc.GetElement(x) for x in sel]
