Create Selec Object WinForm
Hello, I would like to know how I could create the select object in wl winform
import sys
import System
clr.AddReference('System.Windows.Forms')
clr.AddReference('System.Drawing')
from System.Drawing import Point, Image, Bitmap, Size
from System.Windows.Forms import Application, Button, Form, Label, TextBox
class SimpleTextBoxForm(Form):
    def __init__(self, valueA, valueB, imgpath):
        self._imgpath = imgpath
        self._valueInitA = str(valueA)
        self._valueInitB = str(valueB)
        self._pictureBox1 = System.Windows.Forms.PictureBox()
        self._pictureBox1.BeginInit()
        self.Width = 220
        self.Height = 300
        self.textbox = TextBox()
        self.textbox.Text = self._valueInitA
        self.textbox.Location = Point(25, 25)
        self.textbox.Width = 150
        self.textbox1 = TextBox()
        self.textbox1.Text = self._valueInitB
        self.textbox1.Location = Point(25, 55)
        self.textbox1.Width = 150
        self._imageTop = Image.FromFile(self._imgpath)
        self._imageTopResize = Bitmap(self._imageTop, Size(100, 100))
        self._pictureBox1.Location = System.Drawing.Point(45, 90)
        self._pictureBox1.Name = "pictureBox1"
        self._pictureBox1.Size = System.Drawing.Size(100, 100)
        self._pictureBox1.TabIndex = 0
        self._pictureBox1.TabStop = False
        self._pictureBox1.Image = self._imageTopResize
        self.button1 = Button()
        self.button1.Text = 'Press Me'
        self.button1.Location = Point(25, 230)
        self.AcceptButton = self.button1
        self.Controls.Add(self.textbox)
        self.Controls.Add(self.textbox1)
        self.Controls.Add(self.button1)
        self.Controls.Add(self._pictureBox1)
        self.values = []
        self.button1.Click += self.update
        self._pictureBox1.EndInit()
    def update(self, sender, event):
        for control in self.Controls:
            if isinstance(control, TextBox):
              self.values.append(control.Text)
        self.Close()
form = SimpleTextBoxForm(IN[0], IN[1], IN[2])
form.ShowDialog()
OUT = form.values
@Christhian ,
look at pyRevit, also…
KR
Andreas
hi
here an example
import sys
import System
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
from System.Windows.Forms import Application as wApp
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AutoCADNodes')
from Autodesk.Civil import FeatureLinePointType
class Form22(Form):
	def __init__(self):
		self.selectionIds = []
		self.InitializeComponent()
	def InitializeComponent(self):
		self._buttonSelect = System.Windows.Forms.Button()
		self._buttonClose = System.Windows.Forms.Button()
		self.SuspendLayout()
		# buttonSelect
		self._buttonSelect.Location = System.Drawing.Point(64, 73)
		self._buttonSelect.Name = "buttonSelect"
		self._buttonSelect.Size = System.Drawing.Size(170, 41)
		self._buttonSelect.TabIndex = 0
		self._buttonSelect.Text = "Select Object"
		self._buttonSelect.UseVisualStyleBackColor = True
		self._buttonSelect.Click += self.ButtonSelectClick
		# buttonSelect
		self._buttonClose.Location = System.Drawing.Point(64, 120)
		self._buttonClose.Name = "buttonClose"
		self._buttonClose.Size = System.Drawing.Size(170, 41)
		self._buttonClose.TabIndex = 0
		self._buttonClose.Text = "Close"
		self._buttonClose.UseVisualStyleBackColor = True
		self._buttonClose.Click += self.ButtonCloseClick
		# Form27
		self.ClientSize = System.Drawing.Size(298, 200)
		self.Controls.Add(self._buttonSelect)
		self.Controls.Add(self._buttonClose)
		self.Name = "Form27"
		self.Text = "Form27"
		self.ResumeLayout(False)
	def ButtonCloseClick(self, sender, e):
		self.Close()
	def ButtonSelectClick(self, sender, e):
		acSSPrompt = editor.GetSelection()
		if acSSPrompt.Status == PromptStatus.OK:
			acSSet = acSSPrompt.Value
			for s in acSSet:
				if s:
					self.selectionIds.append(s.ObjectId)
		self.Activate()
doc = CivilApplication.ActiveDocument
editor = adoc.Editor
wApp.EnableVisualStyles()
form = Form22()
wApp.Run(form)
OUT = form.selectionIds
@c.poupin Hello, I tried to adapt your code to my code but I have a small error, I don’t know where I am going wrong and I managed to get the select button to appear but when I select it gives me an error
I checked your code and it works perfectly
import sys
import System
        self.Width = 220
        self.Height = 300
        self.buttonSelect = Button()
        self.buttonSelect.Text = 'Select Object'
        self.buttonSelect.Location = Point(25, 185)
        self.Controls.Add(self.buttonSelect)
        self.values = []
        self.buttonSelect.Click += self.selectObject
        self.Close()
    def selectObject(self, sender, event):
        # Lógica para seleccionar el objeto y registrar su valor
        acSSPrompt = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.GetSelection()
        if acSSPrompt.Status == Autodesk.AutoCAD.EditorInput.PromptStatus.OK:
            for s in acSSet:
                if s:
                    self.values.append(str(s.ObjectId))
        self.Activate()
form.ShowDialog()
OUT = form.values
If this were to work one of the outputs would be the selected item
hi,
I add the missing import in my previous post
@c.poupin add what you told me but the error has changed to this other
Application services are part of the accoremgd.dll library - add this line before
You can try this:
import sys
import System
clr.AddReference("RevitAPI")
from Autodesk.Revit.UI import Selection
app = uiapp.Application
    def __init__(self, valueA, valueB):
        self.TopMost = True
        self.Width = 220
        self.Height = 300
        self.values = []
        self.Close()
    	sel = uidoc.Selection.PickObject(Selection.ObjectType.Element)
    	if sel:
    		element = doc.GetElement(sel.ElementId)
    		self.buttonSelect.Text = element.Name
form = SimpleTextBoxForm(IN[0], IN[1])
form.Show()
OUT = form.values
thanks it works as i wish @newshunhk @c.poupin @Mike.Buttery
