Windows pop up - open file on server not url
I have a footer in a windows pop up.
I can set it to go to a URL but i’d like it to go to a link on our company server instead.
I’ve tried changing href to filePath or file but that doesn’t work.
Is is possible?
(Obviously I changed the http to the filepath.)
Most modern browsers will not allow this for security reasons as a URL, but try opening it directly with something like os.system() maybe?
How to Open Files with Python OS - wellsr.com.
you can use TaskDialogCommandLinkId
custombouttontasdialog
an example opening a directory
import sys
import System
my_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.Desktop)
myForum = 'https://forum.dynamobim.com/'
dialog = TaskDialog("Simple Dialog")
dialog.MainInstruction = 'Select Choice'
# Add Button
dialog.CommonButtons = TaskDialogCommonButtons.Cancel
# Add Command Link
dialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink1,
                      'Go To Desktop ?',
                      'open the Desktop directory')
dialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink2,
                      'Go to my favorite forum',
                      myForum)
result = dialog.Show()
if result == TaskDialogResult.CommandLink1:
	System.Diagnostics.Process.Start(my_path)
elif result == TaskDialogResult.CommandLink2:
	System.Diagnostics.Process.Start(myForum)
else:pass
