How do I add a link to a pop-up?
Reading through this: Calling ctypes to create a custom system message - #2 by Gui_Talarico
But can’t work out how to :
1 : add a link from my server (not URL) to the CommandLinks
2: add an e-mail link or to the footer text
3: add hyperlink (a URL) to the command links.
In a Python window in Dynamo
Anyone know?
Hello @Alien
here an example
import sys
import System
clr.AddReference("System.Windows.Forms")
from System.Windows.Forms import Clipboard
# import Revit API
clr.AddReference("RevitAPI")
from Autodesk.Revit.UI import (TaskDialog, TaskDialogCommonButtons,
                               TaskDialogCommandLinkId, TaskDialogResult)
myForum = 'https://forum.dynamobim.com/'
myMail = 'MyNameIsNobody@nowhere.com'
title = 'Task Dialog Title'
dialog = TaskDialog(title)
# Properties
dialog.MainInstruction = 'Text Header'
dialog.MainContent = 'Text Content'
dialog.FooterText = 'Footer Text'
dialog.VerificationText = 'Verification Text'
# dialog.ExpandedContent = expanded_content
# Settings
dialog.TitleAutoPrefix = False
dialog.AllowCancellation = True
# Add Button
dialog.CommonButtons = TaskDialogCommonButtons.Ok | TaskDialogCommonButtons.Yes
# Set Default Button
dialog.DefaultButton = TaskDialogResult.None
# Add Command Link
dialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink1,
                      'Go to my favorite forum',
                      myForum)
dialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink2,
                      'Copy my email in the Clipboard',
                      myMail)
result = dialog.Show()
if result == TaskDialogResult.Ok:
	OUT ='Dialog was OK'
if result == TaskDialogResult.Yes:
	OUT = 'Dialog was Yes'
if result == TaskDialogResult.Cancel:
	OUT = 'Dialog was Cancelled'
if result == TaskDialogResult.CommandLink1:
	System.Diagnostics.Process.Start(myForum)
	OUT = myForum
if result == TaskDialogResult.CommandLink2:
	Clipboard.SetText(myMail)
	OUT = myMail
if dialog.WasVerificationChecked():
	OUT = 'Verification was Checked'
You could also check out the Data-Shapes package.
I love datashapes but unless I’ve missed that node I’m not sure you can just have a pop-up with a URL?
Thank you for that :slight_smile:
Do you know how to make it link to non-URL… for example to
“C:\Users\Default\Pictures” ?
try this
System.Diagnostics.Process.Start(r'C:\Users\Default\Pictures')
hey this is fantastic! Just what I needed. Do you know where I could find a list of available commandlink functions?
Another way to start a URL :
import os
os.system("start \"\" https://example.com")
you can use up to 4 CommandLink see the API doc
Sorry to drag up an old thread…
But … I just cut and pasted that into R23 and it doesn’t seem to work.
Has the syntax changed?
Hi @Alien
there are several issues
  1. in CPython3 the special None keyword can be used as attribute (or enum)
    you can replace
    by
    dialog.DefaultButton = getattr(TaskDialogResult, "None")
  2. then will come an overload problem, you can look at this topic for more information
