Windows Forms PictureBox y Group
Hello I have been trying to add an image and a group in forms but unfortunately I have not been able to reach a solution, can someone help me with that
clr.AddReference('System.Drawing')
clr.AddReference('System.Windows.Forms')
from System.Reflection import Assembly
from System.Windows.Forms import Form
from System.Drawing import Icon
iconFilename = r'D:\ICONOS\5.ico'
icon = Icon(iconFilename)
form = Form()
form.Text = "Hello World"
form.Icon = icon
form.Show()
OUT = form
you need to use this method
you can also store your image as base64 directly in your script
import sys
import System.Drawing
import System.Windows.Forms
from System.Drawing import *
from System.Windows.Forms import *
class Form9(Form):
	def __init__(self, base64Str):
		self._base64Str = base64Str
		self.InitializeComponent()
	def InitializeComponent(self):
		self._pictureBox1 = System.Windows.Forms.PictureBox()
		self._pictureBox1.BeginInit()
		self.SuspendLayout()
		# pictureBox1
		picTop = System.Convert.FromBase64String(self._base64Str)
		self._imageTop = System.Drawing.Image.FromStream(System.IO.MemoryStream(picTop))
		self._imageTopResize = Bitmap(self._imageTop, Size(100, 100))
		self._pictureBox1.Location = System.Drawing.Point(45, 67)
		self._pictureBox1.Name = "pictureBox1"
		self._pictureBox1.Size = System.Drawing.Size(100, 100)
		self._pictureBox1.TabIndex = 0
		self._pictureBox1.TabStop = False
		self._pictureBox1.Image = self._imageTopResize
		# Form9
		self.ClientSize = System.Drawing.Size(284, 261)
		self.Controls.Add(self._pictureBox1)
		self.Name = "Form9"
		self.Text = "Form9"
		self._pictureBox1.EndInit()
		self.ResumeLayout(False)
objForm = Form9(IN[0])
objForm.ShowDialog()
demoBase64_Winform.dyn (16.3 KB)
really surprising, I thank you very much for the solution
@c.poupin I tried to add a couple of texts and a button but it generates an error, could you tell me that I am doing wrong
# Charger les bibliothèques DesignScript et Standard Python
import sys
class Form9(Form):
	def __init__(self, imgpath, valueA, valueB):
		self._imgpath = imgpath
		self._valueInitA = str(valueA)
		self._valueInitB = str(valueB)
		# texBox
		self.textbox = TextBox()
		self.textbox.Text = self._valueInitA
		self.textbox.Location = Point(25, 25)
		self.textbox.Width = 150
		# texBox1
		self.textbox1 = TextBox()
		self.textbox1.Text = self._valueInitB
		self.textbox1.Location = Point(25, 55)
		self.textbox1.Width = 150
		# button1
		self.button1 = Button()
		self.button1.Text = 'Press Me'
		self.button1.Location = Point(25, 125)
		self.AcceptButton = self.button1
		self.Controls.Add(self.textbox)
		self.Controls.Add(self.textbox1)
		self.Controls.Add(self.button1)
		self.values = []
		self.button1.Click += self.update
		# pictureBox1
		self._imageTop = Image.FromFile(self._imgpath)
		# Form9
		self.Name = "Form9"
		self.Text = "Form9"
	def update(self, sender, event):
		for control in self.Controls:
			if isinstance(control, TextBox):
				self.values.append(control.Text)
		self.Close()
objForm = SimpleTextBoxForm(IN[1], IN[2])
the code that I am trying to incorporate is the following
import System
from System.Drawing import Point
from System.Windows.Forms import Application, Button, Form, Label, TextBox
class SimpleTextBoxForm(Form):
    def __init__(self, valueA, valueB):
        self.Width = 220
        self.Height = 200
        self.values = []
        self.Close()
form = SimpleTextBoxForm(IN[0], IN[1])
form.ShowDialog()
OUT = form.values
Hello @Christhian
if you are a beginner on python or on Winform, I do not recommend copying and pasting a piece of code,
(I made this mistake a long time ago when I started in Lisp …)
Here are some interesting resources with IronPython and Winform
I will publish the solution later :wink:
@c.poupin You are absolutely right, I am just starting with python and winform, thank you very much for these guides they will be very helpful, an additional query you know where I can find a guide on the Civil 3d API with python.
I will be waiting for the solution, thank you very much
@c.poupin please do not forget to place the solution
if I did not answer immediately, it is so that you try for yourself with the links given above :slightly_smiling_face:
here an example
import sys
import System
from System.Drawing import Point, Image, Bitmap, Size
    def __init__(self, valueA, valueB, imgpath):
        self.Width = 220
        self.Height = 300
        self._pictureBox1.Location = System.Drawing.Point(45, 90)
        self.button1.Location = Point(25, 230)
        self.values = []
        self.Close()
form = SimpleTextBoxForm(IN[0], IN[1], IN[2])
form.ShowDialog()
OUT = form.values
@c.poupin excellent thank you very much, i will
I will take a look at the guides again and try to take a python course to understand it better
Update to Cpython3 the above code doesn’t work in Cpython3 Environment and I have edited the code as attached below to work. Thanks
import sys
import System
        ((System.ComponentModel.ISupportInitialize)(self._pictureBox1)).BeginInit()
        self.Width = 220
        self.Height = 300
        self.values = []
        ((System.ComponentModel.ISupportInitialize)(self._pictureBox1)).EndInit()
        self.Close()
form.ShowDialog()
OUT = form.values
