Anyone know if it’s possible to embed a base64 image into a windows form using Dynamo 2.6.1.
I tried so many ways and got nothing but errors.
(I gave up and used a linked image instead).
But I was wondering if it’s even possible.
Might be a solution here:
Definitely the solution; the hard part is implementing it in the context of the environment (as usual). ![]()
That’s image from file… As I said, that’s what I ended up doing.
I want to embed a base64 image into the code though…
Am wondering if that is possible.
I had no issue putting a picture or a gif (which was fun) from my harddrive, or the internet
in a pop up window.
Hi @Alien
you have an example in this post (with base64)
Here are some of my failed examples:
clr.AddReference("System.Windows.Forms")
clr.AddReference("System.Drawing")
from System import Convert
from System.IO import MemoryStream
from System.Drawing import Image, Bitmap
from System.Windows.Forms import Application, Form, PictureBox, DockStyle
class CreateWindow(Form):
def __init__(self):
self.Name = "Create Window"
self.Text = "Base64 Image"
self.Width = 400
self.Height = 400
# Base64 encoded image
base64_image = 'I PUT THE BASE 64 CODE HERE BUT DON'T WANT TO TOTALLY SPAM THIS POST'
form = CreateWindow()
Application.Run(form)
I got a blank pop up for the code above.
import System
from System.Windows.Forms import *
from System.Drawing import *
import base64
import io
# Create a form
form = Form()
form.Text = "This is a popup"
form.Width = 500
form.Height = 500
# Create a picture box
picBox = PictureBox()
picBox.SizeMode = PictureBoxSizeMode.StretchImage
picBox.Width = 300
picBox.Height = 300
picBox.Location = System.Drawing.Point(100, 100)
base64_image = 'BASE64 CODE WAS HERE'
image_bytes = base64.b64decode(base64_image)
image_stream = io.BytesIO(image_bytes)
image = System.Drawing.Image.FromStream(image_stream)
# set the image in the PictureBox
picture_box.Image = image
picBox.Image = image
form.Controls.Add(picBox)
# Show the form
form.ShowDialog()
This one gave me TypeError: expected Stream, got BytesIO
