Why the list does not sort by floor in ascending or descending order?
hi all
node sort not work in ascending or descending why?
Revit Elements are not comparible - you have to pull something from them to sort by. Try wiring the GetParameterValueByName node into the Level.Name node, and then use that as a key for a List.SortByKey node, prior to using a GroupByKey node.
fail
  1. Clean or replace your null values. Garbage in results in garbage out.
  2. Set your list lacing and levels to work with the correct data sets.
