Sorting elements by value
Is it possible to sort revit elements by a parameter value? I have a list of elements that I want to use but the elements are not in the correct order, I tried sorting the results from the “Element.GetParameterValueByName” to get the correct order but can’t retrieve the elements from the sorted list. Are there any nodes that will allow me to accomplish this goal? Any help or suggestions would be greatly appreciated, Thanks!
You have a solution below by someone else
SortByFunction will do:
You can also look at how each node works.
https://dictionary.dynamobim.com/2/#/List/Organize/Action/SortByFunction
Thanks it worked!
