Hi, from the title you’re saying you want to write to a file but it looks like you’re using the Read node instead?
Does the file exist?
Do you have read permissions to it?
Is your version of excel compattible with dynamo?
hi
that was right @Dimitar_Venkov
and also give Read as string value as Boolean, not as a string .
have a good day
no matter i write or read, the node Report errors.
the file exist.
what permissions?
I use office 2010 with dynamo 1.3
What is the error? As noted above by @dineshsubramani you are feeding the word True when it expects a boolean value for true
Click on the warning message and say what it shows
Library not registered。
maybe I didn’t install office correctly 。
