whileLoop.dyn (2.2 KB)
Does anybody know a practicle example of a whileLoop?
Maybe combined with a funktion or for loop?
I don’t clearly understand the concept. Sometimes i think it is better to use an If-condition.
KR
Andreas
KR
Andreas
While loops have many uses and usually work with if statements. The two most common I can think of:
Occasionally you may have a while loop that looks like while true: with a break somewhere inside or while x: with x as a variable switch but I don’t have any good specific examples right now.
Ok, thank you … I will continue to investigate issus.
In this particular case, an if statement would work much better. Your while loop is exiting, but not for the reason you want it to.
Zahlen = 26
while Zahlen < 40:
Zahlen = str(Zahlen) + " #Alles unter 40 ist OK!"
OUT = Zahlen
A while loop will continue to execute if the condition (Zahlen < 40, in this case) is True. The first test is 26 < 40, which evaluates to True. The original value of 26, which is an integer, is then replaced with "26 #Alles unter 40 ist OK!". So, the next time the test is done, it will compare "26 #Alles unter 40 ist OK!" to 40 and evaluates to False. A good example of the use for a while loop might be:
my_int = 26
tests = []
while my_int < 40:
tests.append(str(my_int) + " #Alles unter 40 ist OK!")
my_int += 1 # Increment my_int by 1 to ensure loop will exit eventually
OUT = tests
which would output the following:
