my script works well, unit i call the room of my beamer ?
how can i get my instances based on that ?
my code so far?
# đđ Linked electromodel
linked_docs = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RvtLinks).WhereElementIsNotElementType().ToElements()
lnkInstance = [i for i in linked_docs if i.Name.Contains("FM_E")]
doclnk = lnkInstance[0].GetLinkDocument()
# 0ď¸âŁ get rooms
rooms = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Rooms).WhereElementIsNotElementType().ToElements()
# đ get beamers
devices = FilteredElementCollector(doclnk).OfCategory(BuiltInCategory.OST_AudioVisualDevices).WhereElementIsNotElementType().ToElements()
beamer = [ i for i in devices if i.Symbol.FamilyName.Contains("Beamer")]
roomBeamer = [i.Room for i in beamer]
OUT = rooms, devices, roomBeamer
You could use CPython3 or use the get_Room() method
phases = {ph.Name: ph for ph in doc.Phases}
phase = phases["New Construction"] # Use the required phase name
roomBeamer = [i.get_Room(phase) for i in beamer]
Items without a room or not associated with the phase will return null
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
# 0ď¸âŁ get rooms
# đ get beamers
beamers = [ i for i in devices if i.Symbol.FamilyName.Contains("Beamer")]
locationPoints = [i.Location.Point for i in beamers]
points = [i.ToPoint() for i in locationPoints]
output = []
for i in points:
if doc.GetRoomAtPoint(i.ToXyz()) == None:
output.append("No Room")
output.append(doc.GetRoomAtPoint(i.ToXyz()))
OUT = output
Iâve had cases where the default Room property doesnât work and Iâve always been able to work around it with the get_Room[Phase] method. You just need to make sure youâre providing the correct phase otherwise youâll get a null. Although GetRoomAtPoint is valid as long as you ensure youâre using the right phase again.
output = []
for i in points:
OUT = output
You actually are. The default method (with no phase specified) uses the last phase in the project - same as the Room property. Both methods have alternatives to specify the phase you want to query for rooms. Itâs usually pretty safe to assume the final phase is accurate for room data, since most projects donât require rooms on multiple phases anyway.
an example, when rooms are not necessarily created in the last phase
import sys
#import Revit API
doors = DB.FilteredElementCollector(doc).OfCategory(DB.BuiltInCategory.OST_Doors).WhereElementIsNotElementType().ToElements()
room_location_doors = []
for elem in doors:
room = next((elem.get_Room(ph) for ph in doc.Phases if elem.GetPhaseStatus(ph.Id) == DB.ElementOnPhaseStatus.New), None)
room_location_doors.append([elem, room])
OUT = room_location_doors
