Where or how can if find the package that has “X Coordinates” node?
If you go to the Dynamo primer https://primer.dynamobim.org/Appendix/A-2_index-of-nodes.html
You will find that if you have Dynamo you have the node, its standard, or OOTB as they say
Thanks for the help the program I was copying was using “X coordinates” to create a sequence of x points. Replaced it with “Sequence” to do the same thing.
Glad to be of help
