Where is importfromcsv node?
I have downloaded multiple versions of dynamo trying to find the Importfromcsv node. its input is “file type” and the export is “double”
Is this the node you are looking for? If so, it’s located here. I am in Dynamo for Revit 2020, it should be the same location for 2021.
Hope this helps!
i replaced the other one with this one and it works! thank you! :smiley:
You’re welcome!
