Looks like it is a renamed number node.
Yeah, that is a number block with numbers manually typed in. Are you trying to get the elevation of the highest level in your project or the top level of an element like a wall or duct etc…?
I am trying to copy a script of you tube. And this noise is in the script And am trim to get locations from the top center of a plate
Thank you in advance.
Noise should say node.
Sorry about my last email mistakes
I am actually looking for a script that will write coordinate into my element plate parameters properties which I set up as X,Y, Z.
I am a beginner in dynamo. Thank you.
Suggest you make a new topic and show your progress/script for people to assist with. Your initial query is solved.
