What's wrong with the Watch node in Dynamo 2.19 (Revit 2024.2)
Has anyone else encountered this issue, or am I alone here? :frowning:
@danail.momchilov ,
you will need to update, normaly it is active…
grafik
Should have a little arrow in the lower right corner that enables resizing. Try disabling all of your customizations (Dynamo and Revit) and see if that fixes it.
yeap, but those particular ones don’t :slight_smile:
I might try, but it seems like a lot of trouble disabling all the add - ins, packages, etc.
Sometimes you add a second Watch node and it works nicely:
Will carry on like that for now :smiley:
yeap, it’s the same version :slight_smile:
I have found that in some cases it gets stuck as a non-list version.
Restarting the CPU has cleared it most of the time. Or feed it a single item, then re-wire the list.
