What is difference between Bounding Box By Corners and Bounding Box Corners Coordinate System?
Hi Everyone,
I testing with BoundingBox and i don’t know the difference between BoundingBoxByCorners node and BoundingBoxCornersCoordinateSystem node.
As you can see my picture attached, the boundingbox is made from that 2 nodes are same corners but they have not same coordinate origin.
Thank for reading !!
where can I find the node “BoundingBox.ByCornersCoordinateSystem” ? Can you upload your dyn file pls?
Hi Thomas,
That node in geometry section, i’m using dynamo version 0.9
uh ok :slight_smile: I think in 1.2 it is not available anymore with cs. Is there a specific reason why you are not working with a up to date Dynamo version?
@Thomas_Vogt1 @Hien_Ngoc_Tran The node didn’t work and was removed in 1.2. See the long discussion here:
https://github.com/DynamoDS/Dynamo/issues/2243
