Hi all,
Is there a way I can print the entire watch node result in what-you-see-is-what-you-get format (probably as image or pdf)? I want to see the whole output at once or compare two outputs from different scripts.
Hi all,
You could try to export it to a excel sheet. Don’t know if thats what you’re looking for?
I’ll probably lose the nested list level structure there.
Have a go with this node
In the Springs package its named WatchDialog formerly know as Watch+
In the Synthesize Toolkit you will find it under the old name Watch+ node
Thanks @Marcel_Rijsmus.
Thanks for your help!
