hi, im trying to run a python code for moving all the doors in my model to be 18" away from the wall parallel to the door swing at 90 degrees. i havent found any topics on here that discuss the Autodesk. Revit. DB import to be causing issues so any help is greatly appreciated!
Below is my python script:
import math
# Input: List of door elements from Dynamo
doors = IN[0]
# Get the current document
def move_doors(doc, doors):
for door in doors:
location = door.Location
if isinstance(location, LocationCurve):
# For doors with a line location
location_curve = location.Curve
# Get swing angle
swing_param = door.LookupParameter("Swing Angle")
swing_angle = swing_param.AsDouble() if swing_param else 0
# Calculate midpoint
door_position = location_curve.Evaluate(0.5, True) # Midpoint
# Calculate offset direction based on swing angle
rotation_vector = XYZ(math.cos(swing_angle), math.sin(swing_angle), 0)
elif isinstance(location, LocationPoint):
# For doors with a point location
door_position = location.Point
# Assuming swing angle is available for point doors as well
# Skip if the location type is neither
continue
# Offset by 18 inches (converted to feet)
offset = rotation_vector * (18 / 304.8)
# New location
new_location = door_position + offset
# Move the door
ElementTransformUtils.MoveElement(doc, door.Id, new_location - door_position)
# Call the function
# Output: Indicate successful completion
OUT = "Doors moved successfully."
Admin Edit: formatted text
