Walls from Dwg
hello
I’m conscious that many people have already talked about generating walls from DWG, and so far everything is fine. However, I’m stuck with the issue of DWG files containing walls of multiple widths. I can’t figure out how to filter my list according to wall width. Any ideas, community? Thank you.
Could you use a Geometry.DistanceTo node on the line pairs to get the wall thickness?
Example:
Hi @hayet.sassi2 Since the DWG standard is changing, if you could share a sample DWG file, we can try it.
Thank you for replying to me. I understood the error when I tried to group // lines together. In the case shown on the screen, Dynamo recognizes all instances of parallel lines
