Creating walls using DWG -- Criar paredes através de DWG
Good evening everyone, I’d like to create a routine that would draw a wall from my DWG file, but to do that I need to find its axis, since the DWG only has parallel lines 15 cm thick representing my wall. I’ve seen many people with the same question on the forum, and some very old topics. Does anyone have any up-to-date information to make this routine easier?
Boa noite a todos, gostaria de criar uma rotina que fizesse uma parede atraves do meu DWG, mas para isso preciso encontrar o eixo dela, pois no dwg tem somente as linhas paralelas de 15 cm de espessura representando a minha parede, vi muita gente com a mesma dúvida no forum, e alguns tópicos bem antigos, algum tem algo atual para poder facilitar essa rotina?
Hello @maykow-2011 and welcome to the forum :wink:
The forum is in english so just translate your post in the future, here done by google…try share so many data as possible, dyn, image,rvt, cad etc, then your chance of help much better…
try take a look at this post as well…How to get help on the Dynamo forums
I posted about this a while ago as well. Short answer: there is no solution
  1. DWG will have inaccuracies in line length when read from Revit
  2. What happens when Parallel Lines hit a junction?
  3. How do you deal with walls in different layers?
So up to date information is not prevailing because these problems are inherent to the differences of Software
great could you link that post
Here ya go
not for be square :wink: i basic have worth files from acad, and everything is possibly…just about sorting. :wink: hehhehe
