Please help me, I am trying to create wall opening in Revit with Dynamo for MEP services
but get this Error every time.
I have also added it to Dynamo player but same error.
Expects argument type(s), but was called with Error.
I can’t read you’re nodes.
Please zoom in and use “Export Workspace as Image”
The good workflow is to divide cutting openings by two stages:
this error is typically caused by null values in the list. clean it with a bool mask or a node. I have found the nodes to be unreliable, i just use a bool mask.
Thank you for your response, I am new to Dynamo. Do you mind showing me what you mean?
Ok great, where would I insert the Boolean Mask? Sorry if stupid question, Im still new to Dynamo
download the September 2020 version of BIMORPHNODES and your problem will be solved
