I found dynamo script for wall opening by linked MEP model based on Universo-BIM node.
Problem is error what I got from node:
Error is in revit 2024 and 2025, same …
I don’t know is it possible to solve it but I think is it not connected with script itself.
Regards
The DisplayUnitType class has been depreciated since Revit 2021 and removed in Revit 2022 API. The last time Universo_BIM was update was in 2019
Have a look at this forum post here
Dear Mike,
Thank you for fast response … I’ll check that post
Regards
