Get wall face areas in Python
I am trying to get the area of wall faces inside Python script.
The input for Python node are all walls instances selected by Dynamo nodes.
In Python script I retrieve geometry (solids) of each wall instance.
Then I get faces of each solid.
What I want to do is get the area of each face of each wall.
However, I keep getting an error: ‘Face’ object has no attribute ‘Area’.
Revit API states that the Face class has an “Area” property, so I don’t know what I’m doing wrong here.
I would appreciate any help a lot.
clr.AddReference('RevitAPI')
from Revit.Elements import *
import sys
app = uiapp.Application
adoc = doc.ActiveView
wallsWrapped = IN[0]
OUT = []
wallsGeometry = []
wallFaces = []
wallFacesAreas = []
for w in wallsWrapped:
    wallsGeometry.append(w.Geometry()[0])
for i in wallsGeometry:
    wallFaces = i.Faces
    for singleFace in wallFaces:
        wallFacesAreas.append(singleFace.Area)
OUT = wallFaces, wallFacesAreas
Hi, I am not sure the way you extract geometry is correct…
Maybe something like this would work: (just keep in mind the units)
walls = UnwrapElement(IN[0])
clr.AddReference("RevitAPI")
options = Options()
#options.ComputeReferences = True
#options.IncludeNonVisibleObjects = True
faces = []
faceAreas = []
#get side references
for w in walls:
  geoElement = w.get_Geometry(options)
  for obj in geoElement:
    if isinstance(obj,Solid):
      for f in obj.Faces:
        faces.append(f)
        faceAreas.append(f.Area)
OUT = faces, faceAreas
I think you’re actually using the methods inherited from Autodesk.DesignScript.Geometry instead of Autodesk.Revit.DB
Thanks for a quick reply! Indeed it works fine now.
My way of extracting geometry gave me the list of faces so I assumed that this would be correct geometry.
Now I know it doesn’t work like this.
Thank you a lot.
