Wall layers width
I did not get the wall layers’ width in Dynamo. Please advise.
hi …guess thats an element type parameter
im pretty sure there are some nodes to delete and create layers to edit the wall assembly but i doubt you can just change these
not showing the structure width. Only showing total width of wall. I need the every layer’s width.
hi
too late
import sys
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import Wall
w=UnwrapElement(IN[0])
wt=w.WallType
cs=wt.GetCompoundStructure()
OUT = [cs.GetWidth(i)*0.3048 for i in range (cs.LayerCount)]
cordially
christian.stan
