Wall finish face
I need to get a model line to represent the exterior finish face of the wall.
Any ideias?
Thank you!!
@aafonsoBYKA8 ,
we used a generic line based family. Each line represented a surface Typ. at the end we had 96 differend lines(colors) and types.
KR
Andreas
Hi @aafonsoBYKA8,
Use the Wall CompoundStructureLayersLocation node from the Genius Loci package to retrieve the curve locations of the various layers.
Thank you Andreas, but I need some type of automation.
I will try that. Thank you.
Hi @aafonsoBYKA8 not sure if that you want but it could probably work as well if you made some separationline overall the builbing and create a room then you will have the whole perimeter curve exterior
Assuming all the walls are room bounding, I’d utilize the Room.Boundaries node as it would allow creation pretty quickly. Just have to filter out the room separation lines, which could be done by doing a distance comparison.
