Hi Community
I am not sure request node here is fine but that would be nice to have a request TAG for normal user and developer to know whats function need to be <span style=“color: #222222;”>expand.</span>
by the way i am looking for a node adjust for [Wall.ByCurveAndHeight] and [Wall.ByCurveAndLevels].
The current node problem is not able to choice location line and default set as centerline by the curve,
i was try to offset the boundary at blow post but did not work very well with this node:
http://dynamobim.com/forums/topic/create-wall-by-floor-boundary/
Any Idea?
There is no method in the Revit API that has the LocationLine as a variable - so that’s probably why there is no node for this.
In order to make this work nonetheless, you would have to do the following:
Calculate the distance between the wall center line and your desired location line for the wall type you want to place
Offset your curve into the correct direction by the calculated amount
Call the wall creation method and pass the offset curve
Set the location line parameter of the newly created wall to the correct value
Except for step 3 none of the items in the list are entirely trivial, so I’m not sure this is really worth your time.
