Volume of cut floor not correct
Hi again!
I would like to cut a floor with a void. I have done it but the volume of floor is shown as if it has been not cut. Basically it should have been Volume Floor-Volume Void… How can I do it in Dynamo?
It has been done here something similar here but I don’t get it…
https://forums.autodesk.com/t5/revit-api-forum/get-cutting-void-instances-in-the-floor/td-p/7169042
Thanks a milion time!
Volume-3
i did this and got the correct volume. Don´t think you need Dynamo.
Step 1: create floor (check volume)
Step 2: create void geometry and cut with floor (got new volume)
I can check it with your floor if needed. Message me
Thank you for reply. I checked it again, the difference was 0,018 m3 that is why I thought that it had not been cut.
