I finally managed to get it going, and now the script works fine.
Do you have any idea how to filter / make voids through beams and floors? In what direction should I go? Current script (for walls) is attached below:
Best regards, Branimir
Glad to hear you have this sorted out. Please mark the correct solution if you have one so others can refer to this thread if they have the same issue.
Doing the beams and floors should work the same as the walls did. Give it a shot and if not start a new thread so that others on the same boat can quickly see the that solution as well.
hello where can i find the script. I have been trying to solve this problem in my projects for a long time. Thank you.
Hey @brane1012,
is there a possibility to get your dynamo script?
I wanna see how good it works.
best regards Dijvar
Thanks for sharing such useful information,
Can someone give idea where from we can get the used custom nodes i.e.
Geometry Insersection by level
Geometry intersection
Element location
Element collector from linked file
Appreciate the response, Thanks
Regards
Muhammad
@callbowen thanks, it was helpful, however I am still short of used “Element Location” node which is not included in Dynamo4MEP package, can you help with that as well? thanks
Get Location node is out of the box and should be able to replace that. Clockwork has Element Location+
