i’m currently trying to create a dyn script for constructing holes in walls, where there is a duck intersecting, so fare it works on a small project, but when i run the script in a bigger project it gives me a lot of warning’s the primary warning is
Warning: Element.Geometry operation failed.
Value cannot be null.
Parameter name: source.
i’m not certain how i can come around this warning
Won’t be possible for us to figure out the reason for the failure of the Element.Geometry node from the images
Dynamo seems to be having difficulty generating the geometry of some or all of the walls. Identify the troublesome walls first, can then try to identify the problem.
On moving your cursor to the bottom right corner of most nodes a white bar will appear below the node
Move your cursor above it to expand the list
Click on the pin that appears to keep it open
Please do not hesitate to ask any questions, simple or not.
On any Dynamo script with action, they will fail if you have any null values. I tend to use a Boolean mask to dump any null values before for final list goes in for processing. a code block with “” will find “Null” in Dynamo.
